Results 1 to 7 of 7
Thread: Exporting Layouts into AutoCAD
    Member sanjay_yallure's Avatar
    2004-08
    India, Ahmedabad
    10
    Question Exporting Layouts into AutoCAD
    I have 3D model in model space & views where extracted in layout. Know I want to convert &/or export the layout into plain AutoCAD entities. Can it be possible
    Sanjay Yallure
    13,656
    Question Re: Exporting Layouts into AutoCAD
    Quote Originally Posted by sanjay_yallure
    I have drawing made in 3D & views where extracted in layout. Know I want to convert &/or export the layout into plain AutoCAD entities. Can it be possible
    Hi Sanjay
    Which Autodesk product are you wanting to Export from ?
    From your forum signature...
    Inventor Professional 10.0
    Autocad 2006
    Autocad Mechanical 2006
    If not Exporting from AutoCAD, I will move this thread to the appropriate Autodesk product forum.
    Thanks, Mike
    Forum Moderator
    2004-08
    India, Ahmedabad
    10
    Default Re: Exporting Layouts into AutoCAD
    3D models are created in the AutoCAD 2006 itself. Want to export layouts into plain AutoCAD 2006 entities. Exported DWG file does not contain any 3D model. So that size of the file will be reduced considerably.
    13,656
    Thumbs up Re: Exporting Layouts into AutoCAD
    Hi Sanjay
    Thank you for clearing up that matter
    Please note I have *moved* this thread into this forum ( AutoCAD 3D (Pre AutoCAD 2007) ).
    In AutoCAD how have you created the Layouts / Views from your 3D Model ?
    Mike
    I could stop if I wanted to johan d's Avatar
    2006-01
    Belgium
    287
    Maybe you can use this...
    What rests are no real ACAD entities, but rather points...
    http://forums.augi.com/showthread.php?t=34574
    2004-08
    India, Ahmedabad
    10
    Find enclosed the present drawing & final output required.
    2005-10
    Lightbulb Re: Exporting Layouts into AutoCAD
    Hi.
    Perhaps you should use the "solprof" command. It will give you the geometrie on an hidden and a visible.
    The drawing size is a minimum of the dxb-plotting drawing.
  1. Autocad 2009 e layouts
    By n3to in forum Português - AutoCAD / AutoCAD LT
    Last Post: 2008-05-05, 09:14 AM
  2. Autocad 2009 e layouts
    By n3to in forum Italiano - AutoCAD / AutoCAD LT
    Last Post: 2008-04-15, 10:36 AM
  3. Using VBA to create AutoCAD layouts
    By dtownsend in forum VBA/COM Interop
    Last Post: 2006-10-22, 07:06 PM
  4. Exporting Layouts to individual drawing files
    By andrewd in forum AutoCAD Customization
    Last Post: 2006-08-13, 11:39 AM
  5. Exporting Layouts to MicroStation V8
    By kathy.miller in forum Software
    Last Post: 2004-09-16, 02:25 PM
