cadd4la
The blocks that I need counted do not have attributes in them, I need them counted by all in the drawing, by number on a picked layer, or by name of block using a wildcard).
Hi Kyle,
I have done some coding for you. Please give me a feedback on the functionality and errors.
Sub BlockCount_Test()
dispBlockCount "COUNT_ALL"
dispBlockCount "COUNT_BY_LAYER"
dispBlockCount "COUNT_BY_FILTER"
End Sub
Sub dispBlockCount(ByVal strAction As String)
On Error Resume Next
Dim objBlkSet As AcadSelectionSet
Dim objBlkRef As AcadBlockReference
Dim iGpCode(0) As Integer
Dim vDataVal(0) As Variant
Dim iSelMode As Integer
Dim iBlkCnt As Integer
iGpCode(0) = 0
vDataVal(0) = "INSERT"
iBlkCnt = 0
iSelMode = 0 '|-- Selection Modes (0 = Select All, 1 = Select On Screen) --|
Set objBlkSet = getSelSet(iGpCode, vDataVal, iSelMode)
Select Case strAction
Case "COUNT_ALL"
MsgBox objBlkSet.Count, , "Total Block Count"
Case "COUNT_BY_LAYER"
Dim objCadEnt As AcadEntity
Dim vBasePnt As Variant
ThisDrawing.Utility.GetEntity objCadEnt, vBasePnt, "Pick a block reference:"
If Err.Number <> 0 Then
MsgBox "No block references selected."
objBlkSet.Delete
Exit Sub
Else
If objCadEnt.ObjectName = "AcDbBlockReference" Then
Dim objCurBlkRef As AcadBlockReference
Dim strLyrName As String
Set objCurBlkRef = objCadEnt
strLyrName = objCurBlkRef.Layer
For Each objBlkRef In objBlkSet
If StrComp(objBlkRef.Layer, strLyrName, vbTextCompare) = 0 Then
iBlkCnt = iBlkCnt + 1
End If
Next
MsgBox "There are " & iBlkCnt & " block(s) in the layer " & strLyrName, , "Count by Layer"
Else
ThisDrawing.Utility.prompt "The selected object is not a block reference."
End If
End If
Case "COUNT_BY_FILTER"
Dim strFilter As String
strFilter = ThisDrawing.Utility.GetString(False, "Enter a filter option <*>")
If strFilter <> "" Then
If UCase(objBlkRef.Name) Like UCase(strFilter) Then
End If
Next
Else
iBlkCnt = objBlkSet.Count
End If
MsgBox "Search found " & iBlkCnt & " block(s) in the drawing.", , "Count by Filter"
Case Else
ThisDrawing.Utility.prompt "Invalid action mode...."
End Select
objBlkSet.Delete
ThisDrawing.Utility.prompt Err.Description
End If
End Sub
Function getSelSet(ByRef iGpCode() As Integer, vDataVal As Variant, iSelMode As Integer) As AcadSelectionSet
Dim objSSet As AcadSelectionSet
Set objSSet = ThisDrawing.SelectionSets.Add("EntSet")
Select Case iSelMode
Case 0
objSSet.Select acSelectionSetAll, , , iGpCode, vDataVal
Case 1
ReSelect:
objSSet.SelectOnScreen iGpCode, vDataVal
If objSSet.Count = 0 Then
Dim iURep As Integer
iURep = MsgBox("No entities selected, Do you want to select again?", _
vbYesNo, "Select Entity")
If iURep = 6 Then GoTo ReSelect
objSSet.Delete
Set getSelSet = Nothing
Exit Function
End If
Case Else
ThisDrawing.Utility.prompt "Invalid selection mode...."
End Select
Set getSelSet = objSSet
End Function
And how do I code for the userform?
Kyle C.
Since i don't know anything about your userform design, I can not incorporate the code with the form. If you want to use a userform, it's better to convert the dispBlockCount precedure to a function. It's an easy task too.
Hope that helps.
har!s
