Thread: Physical Properties Linking
    Wish List Administration
    2006-03
    1,102
    Default Physical Properties Linking
    Summary: Virtual link of mass properties from an assembly.
    Description: Derive Physical Properties
    How Used: A complex assembly weights XXX KG. We are not going to put this complex assembly in our models, but we do have a simplified part which represents the complex assembly.
    I want to link the weight of the complex assembly to the simplified part. If the complex assembly is altered (more/less parts, parts changing material), the weight of the simplified part will be updated automaticly.
    Feature Affinity: Other
    Submitted By: Teun Ham on March 24, 2006
    2006-04
    3
    Wink Re: Physical Properties Linking
    By reading your wish i think you are not speaking over a derived component.
    I would like to have the option also by a derived component.
    The option should then be mentioned in the dialog box.
  1. CHANGE NON-PHYSICAL PROPERTIES AND NOT BUM THE VERSION
    Last Post: 2012-06-28, 03:49 AM
  2. iFeature Table Control of Physical Properties
    Last Post: 2007-09-30, 05:04 PM
  3. Increase Physical Properties Management
    Last Post: 2006-10-01, 04:30 AM
  4. Physical properties
    By venla.lappalainen in forum Inventor - General
    Last Post: 2006-08-02, 11:47 AM
