Thread: Alignment with station and offset?
    Active Member todd.80290's Avatar
    2004-12
    54
    Default Alignment with station and offset?
    I'm using LDT2005. I have a set of construction plans that label points with station and offset from a baseline. I have set up an alignment for the baseline on the plans. Is there someway for me to input a station and offset and have CAD draw a line there or set a point?
    Thanks, Todd Bronson
    100 Club Phil Ferguson's Avatar
    2002-08
    Buckeye State
    137
    Default Re: Alignment with station and offset?
    Yes.
    To draw a line by station/offset...Use <menu> Lines/Curves > By Station/Offset
    To create a (cogo) point...Use <menu> Points > Create Points - Alignment > Station Offset
    2004-12
    54
    Thanks Phil,
    I never realized those two commands were there.
    Todd
  1. Point Lable Style with Station and offset from alignment
    Last Post: 2016-10-23, 02:21 AM
  2. 2011: label points at an offset from alignment showing stat, offset, and description
    By mw156 in forum AutoCAD Civil 3D - Survey
    Last Post: 2016-09-29, 06:10 PM
  3. 2015: Alignment Station Coordinates
    By mattab222 in forum AutoCAD Civil 3D - General
    Last Post: 2015-07-08, 03:15 PM
  4. Add alignment station offset labels
    By krkeec763189 in forum Dot Net API
    Last Post: 2013-10-07, 09:54 AM
  5. Alignment Station label that is perpendicular to alignment
    By corboto in forum AutoCAD Civil 3D - Alignments
    Last Post: 2010-05-20, 10:43 PM
