Thread: Need help with a routine to change xref layer properties
    2005-03
    3
    Default Need help with a routine to change xref layer properties
    Hello,
    I am in the process of automating some of our normal routines we do to drawings for each project. Here is my problem. We currently x-ref drawings such as topo drawings into our "base" files. I'd like to have a routine that would change the color, linetype, and state of the layers in the xref-ed topo drawing in the base file. Every topo drawing contains the same layers, however each drawing is named different according to the project number (i.e. 3495034topo.dwg, 4928012topo.dwg). I've searched the forum but can't find a lisp or anything else that will work with the different file names. Does anyone know if this is possible or have any suggestions on what to do?
    Thanks in advance for your help!
    Brian
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Default Re: Need help with a routine to change xref layer properties
    You could select the xref to extract the "base" name for the xref. You could then append this "base" name to the standard list of layers to make your layer changes.
    2000-01
    Seattle WA USA
    5,859
    (command "._Layer" "_c" "8" "*Topo|*" "")
  1. Change Table Properties Using Lisp Routine
    By CADdancer in forum AutoCAD Tables
    Last Post: 2023-08-11, 02:20 PM
  2. View/Change Properties in Layer Properties Window
    By mlongfellow in forum AutoCAD General
    Last Post: 2007-12-28, 03:37 PM
  3. Replies: 6
    Last Post: 2007-05-30, 05:45 PM
  4. Ability to Update an XREF Layer from the Layer Properties Manager
    Last Post: 2007-05-08, 12:50 PM
  5. Replies: 10
    Last Post: 2007-04-27, 06:17 PM
