Results 1 to 7 of 7
Thread: Zoom to Outer Space
    Member matt.98118's Avatar
    2005-10
    Oregon
    32
    Default Zoom to Outer Space
    I inserted a component into my model and it must have been way out in outer space. Now if I "zoom to fit" all I see is white space (zooms beyond what will show on my screen). Is there a way to locate my object in outer space and delete it? Zooming to outer space occurs in plan view, 3D views and North/South elevations (for some reason East/West elevation does not zoom to outer space).
    Suggestions?
    All AUGI, all the time christo4robin's Avatar
    2003-05
    Boulder, Colorado
    681
    Default Re: Zoom to Outer Space
    If you know what the object is, locate it in the browser (Expand families, find it, right click, select all). Then delete it once it is selected.
    2005-10
    Oregon
    32
    Quote Originally Posted by 4christo4
    What if I dont know what the object is?
    2005-10
    Oregon
    32
    I got it! I went into 3D view and started making crossing selections until I came across the object way out in space. Deleted! Life is better now!
    AUGI Addict iru69's Avatar
    2004-10
    usa
    1,591
    I've run into this a couple of times. I like how in AutoCAD, no matter how far you've zoomed out (or at least as far as I've ever zoomed out), elements always are represented by at least one pixel. Revit should have something similar.
    100 Club sgoodmansen's Avatar
    2005-10
    Post Falls, ID
    118
    An easier fix is to erase all, then do a shift crossing window over the stuff you know you want to keep.
    2005-10
    Oregon
    32
    Quote Originally Posted by irusun
    Agreed. Sure would make things easier to find in outer space! Where's that "Revit Suggestions" link?
  1. 2011: Keeping xrefs from flying into outer space....How!???!
    By San Antonio Mike in forum AutoCAD LT - General
    Last Post: 2012-11-12, 01:44 PM
  2. Dyn Blk Symbol in Outer Space; Annotation @ 0
    By martins.183886 in forum Dynamic Blocks - Technical
    Last Post: 2010-06-14, 03:28 PM
  3. DEM comes in outer space
    By awhaley in forum AutoCAD Civil 3D - General
    Last Post: 2009-06-03, 02:21 PM
  4. Scroll, Zoom, Spin ... using Space bar
    By gravelin in forum Revit Architecture - Tips & Tricks
    Last Post: 2005-11-05, 09:34 PM
  5. Zoom to option in Find command takes me into space
    By jcfeeken in forum AutoCAD General
    Last Post: 2005-02-09, 03:16 PM
