Thread: Tip to find partially forgotten command
    2016-01
    Manchester,England, UK
    178
    Thumbs up Tip to find partially forgotten command
    I was having a few problems the other day and i couldn't find a variable i needed but i new roughly what it was called but every time i typed in the command line it was wrong.
    So i asked a friend of mine does he know it and he didn't but he told me to do the following.
    If you type in the first letter or letters of a command on the command line, but you don't know or can not remember the full name, you can press the TAB key and it will cycle through all the commands beginning with the letters you entered. Works on 2006 but I don't know if it works on earlier versions..
    Give it a try it worked for me..
    Gareth
    I could stop if I wanted to JASONM30395's Avatar
    2002-04
    Halifax NS Canada
    397
    Default Re: Tip to find partially forgotten command
    In 2k5 and above if you type SYSVDLG at the command prompt you get a dialog box with all the sysvars
    Loyalty above all else except honor
    For my honor is my life!
    2015-10
    Easton, Maryland
    15
    In LDT and C3D the command "SYSVDLG" does not work you get an error response unkown command.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,115
    Quote Originally Posted by hlecates
    It's an Express Tool. You would need to load the Express Tools for it to work.
    0,0,0 The Origin
    8,570
    In any version, type SETVAR then ? then ENTER and page through the listings.
    Doesn't work with commands, though.
  1. Where to find the ShrinkWrap command?
    By CadDog in forum AutoCAD General
    Last Post: 2016-07-21, 05:50 PM
  2. 2012: Find/Replace command help
    By dmusika in forum AutoCAD General
    Last Post: 2012-10-16, 05:12 PM
  3. FASTSELECT command, can not find any help on it
    By clarkrj in forum AutoCAD General
    Last Post: 2006-06-13, 01:55 PM
  4. Find and Replace Command
    By son.do in forum AutoCAD General
    Last Post: 2005-01-31, 10:40 PM
