Thread: editing filled regions side by side
    2003-04
    Scotland
    1,577
    Default
    Say I have 3 filled regions all next door to each other, I go into sketch mode to edit ONE of them - it changes the others - even if the lines are not locked, especially when dealing with angles this is bad. I edit one, I only want one to change, I wcan change the others myself if I want to. This is a real headache causer this one - Revit people, please make it stop.
    2003-04
    London NW9
    377
    Default Re: editing filled regions side by side
    This is only the case is the 3 filled regions were sketched at the same time ?
    This is the nature of the filled region command
    Surely if you do 'seperate' filled regions you are then OK ?
    2003-04
    Scotland
    1,577
    Nope, 3 completely separate filled regions - although the borders overlap each other - adjusting one of them in sketch mode messes up the angles on the others, and the lines are not locked to each other.....
  1. Model as a Layout, Side by Side on the Screen
    Last Post: 2013-06-09, 09:39 PM
  2. will 2010 and 2009 work side by side?
    By Les Therrien in forum Revit Architecture - General
    Last Post: 2009-04-21, 12:17 AM
  3. Ability to View Multiple Drawing Sheets Side by Side
    Last Post: 2008-06-06, 05:12 PM
  4. Access long side and short side info of an Ellipse
    By rwbaker54 in forum VBA/COM Interop
    Last Post: 2006-03-29, 04:00 PM
