Results 1 to 1 of 1
Thread: Blocks, Images or Xrefs not inserting correctly?
    2001-12
    St. Louis
    5,407
    Default Blocks, Images or Xrefs not inserting correctly?
    The following compilation of tips comes from programming forum moderator, Opie. Thank you!
    Have you inserted Blocks, Images or Xrefs only to find they scale automatically to a different scale from what you specified?
    AutoCAD makes use of the following system variables when inserting any of the three above mentioned Objects...
    INSUNITS - Specifies a drawing-units value for automatic scaling of blocks, images, or xrefs inserted or attached to a drawing.
    INSUNITSDEFSOURCE - Sets source content units value when INSUNITS is set to 0. Valid range is 0 to 20.
    INSUNITSDEFTARGET - Sets target drawing units value when INSUNITS is set to 0. Valid range is 0 to 20.
    These system variables allow AutoCAD to automatically scale Blocks, Images or Xrefs, thus reducing your need to scale them to your current working scale.
    The following are some links that shed some more light on the subject.
    AutoCAD Knowledge Base:
    ID: TS1050553 - Automatic scaling of blocks
    ID: TS20081 - Using the Insert Units option for blocks inserted from AutoCAD DesignCenter
    ID: TS30666 - Set drawing units for inserted blocks and images
    ID: TS1050419 - New or changed system variables in AutoCAD 2006
    ID: TS1056208 - INSUNITS change after reopening drawing
    AUGI Forums:
    Scale changes when block is inserted
    Inserting Xrefs Scaling Problems
    Set INSUNITS to Metric when opening a drawing
    Setting insertion units at open
    Blocks scaling when inserted from Tool Palette
    unit-scaling inserted database?
    Inserts scaled wrong
    Unit problems when XREFing drawings that have block units set different
    Symbol Scale Inserting Issue
    Loading Xrefs come in at different locations
    Unit Conversion; Block Scaling when Inserting or X-refing
    Macro - Scale problem between AutoCAD 2005 to 2006
    When Blocks are Inserted they come in too small
    Xref reloading problems
    Blocks come in at different Scales in different drawing files.
    2004 & 2006 Xref's come in at different locations ?
    Blocked Inserted is Wrong Scale
    Inserted Blocks in 2007 come in at different scales
    Blocks insert larger in one drawing file than another
    Block being inserted at wrong scale
    Insert units won't change
    AutoCAD 2007 Drawing Units with regarding Blocks and Insert command
    Best practises for Templates, Design Center and Tool Palettes
    Symbols coming in at wrong scale
    Paste As Block creates a Block 32x bigger
    Blocks inserting at different scales?
    Insert a Layout via Designcenter, the Border / Titleblock scales up by 25.4
    Last edited by Mike.Perry; 2007-05-11 at 03:37 AM. Reason: Additional information added.
  1. 2011: Inserting Images
    By dgaertner in forum AutoCAD LT - General
    Last Post: 2013-05-05, 12:06 PM
  2. Wall based family not inserting correctly
    By charliep in forum Revit Architecture - Families
    Last Post: 2008-10-31, 10:35 PM
  3. Inserting Images
    By cadmanrobb in forum AutoCAD General
    Last Post: 2008-05-08, 03:11 PM
  4. INSERTing a drawing that has XREFs
    By LanceMcHatton in forum AutoCAD General
    Last Post: 2008-03-20, 06:32 PM
  5. Inserting Xrefs Scaling Problems
    By jmcshane in forum AutoCAD General
    Last Post: 2005-07-15, 04:11 AM
