Thread: Multiple command macro within pulldown menu
    2004-01
    21
    Default Multiple command macro within pulldown menu
    i am trying to xref a fastener into my drawings and then the symbols right behind it as i used to use the insert command and it worked fine. the following is the macro i am using the first x-ref comes in but not the second
    ^C^C-XREF A S:/fastener/f1; ^C^C-INSERT S:/SYMBOLS/FASTMARK ;;;2
    i the process of using the xref i noticed this (Xref "f1" has already been defined.
    Using existing definition.) the whole i reason i wanted to get away from insert command to bring blocks into my drawings was to make sure i would get the current drawing and not some duplicate definition. Or does it only use a duplicate of the block through xref when the block has not been altered.
    anyway if somebody knows what is wrong with my macro it would be greatly appreciated as i have about a 1000 macro to fix and need to get going
    13,656
    Default Re: Multiple command macro within pulldown menu
    Hi
    Please note I have *moved* this thread from the AutoCAD CUI Menus forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
    13,656
    Question Re: Multiple command macro within pulldown menu
    Hi
    Quote Originally Posted by louis.64641
    Are you saying the above command macro does not work ?
    If yes, try this...
    ^C^C_.-XRef;_A;"S:/fastener/f1";\;;;_.-Insert;"S:/SYMBOLS/FASTMARK";\;;;
    If no, please give more details.
    i the process of using the xref i noticed this (Xref "f1" has already been defined using existing definition.) the whole i reason i wanted to get away from insert command to bring blocks into my drawings was to make sure i would get the current drawing and not some duplicate definition. Or does it only use a duplicate of the block through xref when the block has not been altered.
    Are you saying Xref "f1" is already Xref'd into the drawing file before you attempt to run your command macro ?
    Have a good one, Mike
  1. convert pulldown menu to ribbon
    By andy.millard in forum AutoCAD CUI Menus
    Last Post: 2009-10-23, 05:11 PM
  2. Custom pulldown menu items
    By revituser195 in forum Revit Architecture - General
    Last Post: 2009-04-02, 06:02 PM
  3. Where is the tools pulldown menu
    By Dave Lewis in forum ACA General
    Last Post: 2007-02-02, 01:28 AM
  4. Command macro in Image Menu
    By sifuentes in forum AutoCAD Customization
    Last Post: 2006-05-24, 10:17 PM
  5. Layer Snapshot in Command Line or Menu Macro
    By dhallett in forum AutoLISP
    Last Post: 2005-05-17, 06:18 PM
