Results 1 to 10 of 15
Thread: Printing to EPS from Revit.....
    2005-05
    17
    Exclamation Printing to EPS from Revit.....
    ...Is this acheivable?
    We are having issues with generating decent un-rendered images form Revit. We are often in a rush and do not have the time to render images and are therefore looking for alternatives.
    We know we can use .pdf but I have read a thread here where some-one hints at being able to print files to eps format. Doed anyone know how this is done?
    All AUGI, all the time gbrowne's Avatar
    2004-03
    Glasgow, Scotland
    579
    Default Re: Printing to EPS from Revit.....
    Haven't tried it, but if you have Illustrator, you can do the revit-pdf-illustrator-EPS dance?
    or try this thread..
    http://forums.augi.com/showthread.ph...ighlight=files
    AUGI Addict aggockel50321's Avatar
    2003-05
    Waterville, Maine
    1,748
    You'd need a windows driver to print to eps, to do it directly from Revit.
    I haven't used this one, but saw it recently. It may do what you want.
    All AUGI, all the time cphubb's Avatar
    2003-11
    Seattle
    691
    Pretty much any good PS printer driver set to file will work.
    We use our HP755PS driver and get good results using distiller to make PDF from EPS.
    2003-05
    East Walpole, MA
    893
    Forgive me, but what is "EPS?"
    2002-02
    St. Louis, MO
    4,695
    Ecapsulated Postscript file.... Really the same as a PS file, but has information about how it could be inserted into another file using a bounding box. That's the E part. The PS part is information for getting graphics printed.
    2004-10
    20
    Unhappy Re: Printing to EPS from Revit.....
    That is not possible yet. If you have Autocad, you can transfer to dwg and then print to eps2 in the printers option. The result is excellent.
    I think this is a topic that could be in the Revit wishlist, since many people don't have Autocad and exporting to jpeg. from Revit even at 600dpi is not a good option.
    I could stop if I wanted to Phil Read's Avatar
    2003-05
    Charlotte, NC
    398
    Quote Originally Posted by arskrasows
    Incorrect. You *can* print EPS files directly from Revit with no conversion/exporting. The resolution is extraordinary. All you need to install a Postscript driver (free from Adobe) which utilizes a PDD (Printer Definition File - just read further down the same link). Here's the download site for both drivers:
    http://www.adobe.com/support/downloa...atform=Windows
    HP 755CM PDD file is really great. You can keep the EPS files as is - or convert to PDF. Again - fantastic resolution. Basically you're Printing to File. To simplify things I change the default extension from *.plt to *.eps before printing.
    Here's an EPS and PDF from the Revit Hotel (R5) project. Plotting this sheet as an EPS took about 20 seconds.
    All the best -
    Phil
    2005-07
    3,250
    I did this a week ago, but have not been successful. For some reason, when I do a print preview, everything is fine and dandy, shows up centered as expected on the sheet. Once it prints and I open the eps, it's offset and half the drawing is cut off the sheet. I'm using exactly the drivers in your link.
    I'm quite disappointed in the export to jpg function with Revit by the way. For some quick presentations on 11x17, you can export shaded views just fine, but if you want to enlarge, say on 24x30, the jpg looks bad, regardless of what resolution/size you set it. You have to render to get a decent result. This was the reason I was thinking of using eps files.
    2004-03
    Glasgow, Scotland
    579
    For that very reason, we print off as .pdf. Resolution is much better.
  1. Revit Printing to Pdf's
    By christine.davis in forum Revit - Plotting/Printing/Exporting
    Last Post: 2008-11-10, 11:45 PM
  2. Printing in Revit???
    By cadman6735 in forum Revit Architecture - General
    Last Post: 2008-10-14, 10:07 PM
  3. Printing without Revit??
    By whf in forum Revit - Plotting/Printing/Exporting
    Last Post: 2008-02-06, 03:16 PM
  4. Printing PDF from Revit
    By eric.anastas in forum Revit Architecture - General
    Last Post: 2006-11-13, 04:41 PM
  5. Revit Printing
    By ChristinaB in forum Revit Architecture - General
    Last Post: 2005-02-28, 09:48 PM
