Thread: Using Layer names with spaces in them, inside of a Script
    2006-04
    3
    Default Using Layer names with spaces in them, inside of a Script
    In script file, if the layer name with space(e.g. dimension (ANSI)), how to make it work?
    Because in script, space means 'Enter'.
    13,656
    Default Re: Using Layer names with spaces in them, inside of a Script
    Hi
    Please note I have *moved* this thread from the Local User Groups forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
    13,656
    Hi
    Try the following threads...
    want to rename layers in a script
    Spaces in macro's
    How to use Layer names with spaces in
    Have a good one, Mike
    2006-04
    3
    Thanks, Mike, I get it. Today I post another problem about how to use explode command in script, hope get your help again.
    Amy Chen
  1. 2015: AutoCAD 2015 doesn't like layer names with spaces and dashes
    By awander in forum AutoCAD General
    Last Post: 2014-06-19, 11:43 AM
  2. Room Names and Spaces
    By sjsl in forum Revit MEP - General
    Last Post: 2010-06-11, 06:22 PM
  3. Replies: 14
    Last Post: 2010-03-24, 05:13 AM
  4. Change Layer names to other Layer names via a script?
    By tburke in forum AutoCAD Customization
    Last Post: 2006-12-04, 07:30 PM
  5. How to use Layer names with spaces in
    By b_v_mc in forum AutoCAD Customization
    Last Post: 2005-07-14, 02:25 PM
