rduprey
ASHISH,
I guess your situation arises when you have views in diffferent scales, and you want the text to match from one view to the other. To my knowledge, the only way to change leader text to a match different dimstyle is to create another leader in the new style and then use "match properties" to resize the text. It's not the best way, as other properties, like the text justification, etc. also have to match.
I have come to do my dimensions in model space through the viewport windows in paper space; In the "fit" tab of the dimension style manager I set to "scale dimensions to layout", then I lock the viewport (MV>Lock>On>pick) so I can zoom freely without change the viewport scale, I enter model space through the given viewport, and the dimension are automatically scaled. It take a little of the guesswork out of matching your dimension through out a layout. You may be able to use a single dimension style for all scales.
I'm not sure if this addresses your problem, but hope it helps.
R duPrey
