Results 1 to 9 of 9
Thread: Intersecting Walls not cleaning up?
    2003-07
    142
    Default
    I have just started using 6.1. I drew a wall thro another and the intersection didn't clean up. I do not remember having this problem with 5.1. How do correct this setting?
    Jason
    2003-04
    Chino, CA
    4,756
    Default Re: Intersecting Walls not cleaning up?
    split one of the walls at the intersection.
    2003-07
    142
    Scott, is that the only way? I thought it cleans up the intersection itself. I want to be able to move the whole wall for design refinement. In your scenerio, I would have to one wall and align the other to it. I guess I could group the walls.
    J
    2003-05
    5,153
    Hi Jason,
    Lock-align one piece of wall to the other. It will move automatically with the first then.
    2003-07
    142
    Hi Beegee,
    How do you do lock-align?
    I thank you in advance.
    Jason
    2003-05
    5,153
    After you use the align tool, a blue open padlock appears. Click to lock it and you're done.
    2003-04
    Chino, CA
    4,756
    You are correct that wall clean-ups occur automatically. But Revit alos makes you think as you are building real walls. You would never have one wall pass through another. One wall might be continuous, while the 'intersecting' wall will stop and start at the face of the continuous wall. This is why splitting the wall makes the walls clean up. It has been this way in Revit since r1.0.
    Beegee's recommendation to align-lock them is the best way to make the two parts move together. The align and lock method works for many situations, too. You could have two separate walls across the plan from each other, and they could be locked together.
    Click the Align tool, then pick the face or core of the wall you want to align to, then click the corresponding wall face or core of the other wall. The walls will 'snap' to alignment, and the blue lock symbol will appear. Click the lock symbol to 'close' the lock.
    2005-01
    4
    hi scott
    have the following problem:
    draw a wall on top (less thick than the other wall underneath) and this "top" walls won' t join.
    what to do?
    thanks
    stefan
    I could stop if I wanted to Nic M.'s Avatar
    2001-11
    Antwerp, Belgium
    480
    Can you post an example?
    Did you use the join geometry button?
    It does join in my try
  1. Intersecting walls
    By h.s.meijering in forum Revit - Student Support
    Last Post: 2010-02-16, 03:46 PM
  2. Walls intersecting columns?
    By marcu_p_mihai in forum Revit - Platform
    Last Post: 2009-09-11, 03:12 PM
  3. walls not cleaning up
    By Bryan Thatcher in forum ACA General
    Last Post: 2009-05-28, 03:29 PM
  4. Split Face & Intersecting walls
    By DaveP in forum Revit Architecture - General
    Last Post: 2008-03-20, 05:45 PM
  5. Endcaps and Intersecting walls
    By dhallett in forum ACA General
    Last Post: 2005-02-22, 11:46 PM
