We don't need the other two shape files.
I should have pointed you to my web page on shape files [http://rkmcswain.blogspot.com/2006/0...hape-file.html ]. I have a lisp there that will produce a summary report on shape file usage. Here is the report on your drawing.
LINETYPE [BARBED] uses SHAPE # [12] in the file [C:\MECON\MECON.SHX]
LINETYPE [PWPL] uses SHAPE # [2] in the file [C:\MECON\MECON.SHX]
LINETYPE [CAB1] uses SHAPE # [13] in the file [C:\MECON\MECON.SHX]
LINETYPE [CLT] uses SHAPE # [16] in the file [C:\MECON\MECON.SHX]
LINETYPE [UAPL] uses SHAPE # [1] in the file [C:\MECON\MECON1.SHX]
LINETYPE [FADWPL] uses SHAPE # [1] in the file [C:\MECON\MECON.SHX]
LINETYPE [PW] uses SHAPE # [2] in the file [C:\MECON\MECON1.SHX]
LINETYPE [OPT] uses SHAPE # [3] in the file [C:\MECON\MECON1.SHX]
LINETYPE [GLC] uses SHAPE # [4] in the file [C:\MECON\MECON1.SHX]
LINETYPE [EP] uses SHAPE # [6] in the file [C:\MECON\MECON1.SHX]
LINETYPE [M6] uses SHAPE # [9] in the file [D:\LEARN\AMAP\LINETYPES\.\.\.\.\.\.\.\.\MAGNASOFT]
LINETYPE [M8] uses SHAPE # [18] in the file [D:\LEARN\AMAP\LINETYPES\.\.\.\.\.\.\.\.\.\.\.\MAGNASOFT]
LINETYPE [SFS] uses SHAPE # [1] in the file [D:\MEC-E117.C.00.50-101-Souvik\NEWSHP]
LINETYPE [A] uses SHAPE # [6] in the file [D:\MEC-E117.C.00.50-101-Souvik on Mac9 on mac8 (Stpl8)\newshp.shx]
The following SHAPE FILE is loaded: [C:\MECON\MECON.SHX]
The following SHAPE FILE is loaded: [C:\MECON\MECON1.SHX]
The following SHAPE FILE is loaded: [D:\LEARN\AMAP\LINETYPES\.\.\.\.\.\.\.\.\MAGNASOFT]
The following SHAPE FILE is loaded: [D:\LEARN\AMAP\LINETYPES\.\.\.\.\.\.\.\.\.\.\.\MAGNASOFT]
The following SHAPE FILE is loaded: [D:\MEC-E117.C.00.50-101-Souvik\NEWSHP]
The following SHAPE FILE is loaded: [D:\MEC-E117.C.00.50-101-Souvik on Mac9 on mac8 (Stpl8)\newshp.shx]
An unknown shape is INSERTED in *Model_Space at (4742.66 3919.91 0.0)
An unknown shape is INSERTED in *Model_Space at (4745.81 3916.41 0.0)
This path:
...is 65 characters - hence the message you are receiving.
Purge those shapes and reattach using a shorter path.
