Thread: Image Published to DWF Does Not Plot
    2001-11
    74
    Default Image Published to DWF Does Not Plot
    I published a drawing with a TIF image to a DWF. I can view the DWF in Composer, but it will not plot the image, only the vector portions. I have tried several different DWF pc3 files and have tried it from 2005 and 2006. It is not on a "noplot" layer. Does anyone have any suggestions?
    13,656
    Question Re: Image Published to DWF Does Not Plot
    Quote Originally Posted by jmorgan
    Hi
    Just checking here...
    Is the Image within the DWF file viewable inside of DWF Composer ?
    What about when viewed inside of DWF Viewer ?
    Does the drawing file output ok! when Plotted to an output device ie Does the Image attached to the drawing file appear on the paper output ?
    Have a good one, Mike
  1. Plot to PLT or Image format
    By mr_maroo in forum AutoCAD Plotting
    Last Post: 2007-11-24, 05:09 PM
  2. Published 2D DWF/image problem
    By MTristram in forum Revit Architecture - General
    Last Post: 2007-10-03, 11:20 PM
  3. Image not showing up on Plot.
    By boofredlay in forum Revit Architecture - General
    Last Post: 2006-11-27, 03:49 PM
  4. IMAGE WON'T PLOT
    By Richard McDonald in forum AutoCAD Plotting
    Last Post: 2005-08-04, 02:42 PM
  5. Image does not plot
    By alexo in forum AutoCAD Plotting
    Last Post: 2004-10-07, 11:53 PM
