Thread: Re-Assigning Elevation Level Heights - Need Help!
    Member razorx1858's Avatar
    2003-12
    Philadelphia
    28
    Default
    Hi Guys,
    I had to make an adjustment to my finished floor which required my to drop it from 0'-0" to -1'-6". The problem is that I don't know how to re-name the "-1'-6" to say 0'-0"
    Is there a way I can re-assign the -1'-6" elevation so it's actually 0'-0" a.f.f.? Thus re-dimensioning all other elevation level heights based upon this new 0'-0"?
    Any help would be most excellent.
    2003-05
    5,153
    Default Re: Re-Assigning Elevation Level Heights - Need Help!
    Lock all your levels using a dimension string.
    Reassign the lower level to 0.0 and the other levels will change also, but stay relative to 0.0.
    Bruce Gow.
    Karel*CAD. Application Specialist..
    Architect.
    Revitalize. Blog
    2003-12
    Philadelphia
    28
    Beegee! You are the best, I don't care what anybody says!
  1. changing level heights
    By ..shaner in forum Revit Architecture - General
    Last Post: 2009-10-28, 07:55 PM
  2. Assigning Elevation to a Layer
    By ljupadhyay in forum ACA Wish List
    Last Post: 2007-04-24, 05:03 PM
  3. Altering all level heights
    By MedJohn in forum Revit Architecture - General
    Last Post: 2006-08-18, 05:04 PM
  4. Level elevation heights in Design Options
    By ctc in forum Revit Architecture - General
    Last Post: 2005-11-03, 04:59 PM
  5. Different cut plane heights for a level
    By cadkiller in forum Revit Architecture - General
    Last Post: 2005-03-19, 11:35 PM
