Summary: Ability to apply tolerances to a constraint
Description: I wish you could tolerance a constraint.
How Used: I'd give certain constraints, such as an insert constraint a tolerance. This would allow you to align parts or models that aren't exact, just as you would in the real world. The best example in my line of work is the fit between an alignment pin and a mounting plate. I run into this problem the most with models brought in from mfg's sites.
Feature Affinity: Assemblies
Submitted By: Heath White on April 11, 2006
