Results 1 to 10 of 12
Thread: Deploy TrueView custom profiles
    Default Deploy TrueView custom profiles
    Be nice if we could use custom profiles in TrueView. As it is not, you need to change the configuration but it only sticks for that user who's logged in. Be nice to point all users to our network based plotter configs.
    13,656
    Thumbs up Re: Deploy TrueView custom profiles
    Quote Originally Posted by DarrenYoung
    Hi Darren
    I like that one... it is very good one.
    Mike
    2007-09
    31
    Default Re: Deploy TrueView custom profiles
    I created a custom profile in architectural desktop 2007 on one machine, and want to transfer that profile to another machine with plain AutoCAD 2007. I copied the custom profile to a floppy. Then copied from the floppy to where AutoCAD stores the profiles.
    When I try to import through the options and navigate to where I put the files, AutoCAD does not recognize them. What do I need to need to do?
    9,805
    Exclamation Re: Deploy TrueView custom profiles
    Quote Originally Posted by DarrenYoung View Post
    You can do this now. Create a .REG file and import it for each user using the windows logon script.
    More info: http://rkmcswain.blogspot.com/2005/1...-trueview.html
    2007-09
    31
    It’s asking for an *.ARG file.
    How do I get it to read a .REG file?
    I created a new profile in AutoCAD 2007 that creates an .aws file.
    So I tried replacing that one with mine, didn’t work.
    9,805
    Lightbulb Re: Deploy TrueView custom profiles
    Quote Originally Posted by ekohles View Post
    My response was to DarrenYoung (see quoted part of my message)
    I've since found a different method I like better. I just use Microsoft's Orca utility to edit the MSI file so upon install, it's what I need.
    I don't think you'll have any luck getting plain AutoCAD to read an ADT or other vertical produc'ts profile (ARG).
    Also, an ARG file is a REG file except that there's some AutoCAD variables in it that get replaced when AutoCAD imports the profile. Renaming it to a REG and double slicking it would import it into your registry but without editing a lof of the data in the ARG (highly not recommended), you're likely to mess up your existing profiles.
    Also recommend posting your inquiry to one of the ADT or plain AutoCAD groups. Tihs discussion group is specific to TrueView/
    2005-09
    I've opened Trueview's MSI in Orca, but it's not obvious to me where and how exactly to add additional support paths that I would like to be included in each user's Trueview options.
    Can you give any direction?
    2008-03
    Laurel, MD
    509
    Another option is a script that creates a reg file and the brings it in.
  1. Custom hatch pattern display / print / PDF conversion issue in TrueView
    By cad.238271 in forum DWG TrueView - General
    Last Post: 2013-02-15, 10:09 PM
  2. Deploy Tool bar
    By zride91 in forum AutoCAD Customization
    Last Post: 2009-07-28, 11:08 PM
  3. Revit deploy scripts
    By Dave Lewis in forum Revit Architecture - General
    Last Post: 2009-01-26, 05:49 PM
  4. Deploy AutoCAD/MEP/Arch w/ custom cui documentation
    By dbanker in forum CAD Management - General
    Last Post: 2008-06-30, 02:09 PM
  5. Ability to Create Custom Profiles in Frame Generator
    Last Post: 2007-01-02, 06:19 PM
