I am trying to set up a field that shows the plot date (or any date really for that matter). I can get it to work just fine, with one exception - as req'd by the client standard, the date should be in this format 12 APR 06
I can get this to show up in this format no problem using dd MMM yy, except that I cannot get the month to come in in all caps, it defaults to Apr. I thought maybe the upper case M would do the trick, but that's not the case, as the lower case is for minutes.
Does anyone know of another way to get this to work? I basically just need to change the formatting to be all caps, and I've tried several things with no luck. This is in Acad 2005.
Thanks!
