Thread: Plus/Minus
    2003-05
    Toronto
    76
    Default
    Is there a way to add Plus/Minus to a dimension string
    2001-12
    Irvine, CA
    7,563
    Default Re: Plus/Minus
    If there is a better way I'm all ears (need a new emoticon for that huh?)...but I add a suffix of +/- to the dimensions via the properties dialog.
    Autodesk Revit CSE
    2003-05
    New York, NY
    42
    Alek,
    Select on a dimesnion and go to the properties of the dimension there is a Prefix / Suffix instance parameter.
    If there is more than one dimension in the string then the Prefix / Suffix value is set to the entire string (i don't know if we can control this). If only one of the dimensions within the string needs a plus / minus use text or a symbol etc.
    2003-04
    Chino, CA
    4,756
    You can add a prefix that is text: +/-
    seems to work....its not the stacked plus-minus but......
    Scott D Davis
    Sr AEC Technical Specialist
    Autodesk, Inc.
    http://about.me/scottddavis
    2003-05
    Vancouver Canada
    52
    If you use your character map you can get the stacked ± into your dim prefix. The short cut code is alt+0177. I believe that is the standard for all fonts that offer extended characters.
    cheers
    Bryan
  1. Plus/Minus Symbol
    By jcoe in forum Revit Architecture - General
    Last Post: 2019-01-14, 08:11 PM
  2. Plus or Minus Sign
    By TipToeUp2 in forum Revit - Student Support
    Last Post: 2015-09-07, 06:14 AM
  3. Allow plus or minus a distance on extrude To
    By autocad.wishlist1734 in forum Inventor Wish List
    Last Post: 2013-12-26, 08:26 PM
  4. Revit to Max (minus mental ray?)
    By Dan C in forum Revit - Plotting/Printing/Exporting
    Last Post: 2009-09-17, 11:59 AM
