Results 1 to 7 of 7
Thread: Move 3D LISP
    2006-03
    6
    Default Move 3D LISP
    Im very new to Autolisp so can someone help me with creating simple routine. all i want to do is save time when moving objects in 3d by not typing in: move then 0,0, before the height i want to move my object. i just want a simple command to be able to click and then just type in the height so my object moves on the z axis i no this is prob dead simple to a lot of people but it will help me get started
    Thanks
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,442
    Default Re: Move 3D LISP
    Have you seen the announcement for the current ATP class on Lisp?
    2005-08
    1,043
    Maybe something like.
    (defun c:MoveZ (/ ss Zval)
    (if
     (and
      (setq ss (ssget))
      (setq Zval (getdist "\n Enter distance to move along Z axis: "))
     (command "_.move" ss "" '(0.0 0.0 0.0) (list 0.0 0.0 Zval))
    (princ)
    2006-03
    6
    Cheers i dont understand how but it works so thanks alot
    2002-01
    jUSt Here (a lot)
    8,442
    Quote Originally Posted by m.tolson
    It checks to see if entities are selected and made into a selection set. It also asks for the distance to move.
    It then starts the move command, supplies the selection set and then moves the selection set vertically based on the distance you provide.
    2005-08
    1,043
    Quote Originally Posted by Opie
    Thanks Opie.
    2002-01
    jUSt Here (a lot)
    8,442
    Quote Originally Posted by T.Willey
    Thanks Opie.
    You did the work. I just tried to translate it into English.
  1. LISP to move up or down
    By j.p.lackey678678 in forum AutoLISP
    Last Post: 2014-11-24, 07:25 PM
  2. Move MText at a certain Z value LISP
    By djin_fre3449006 in forum AutoLISP
    Last Post: 2013-11-28, 08:17 AM
  3. Lisp to move block along line
    By jayhay35365091 in forum AutoLISP
    Last Post: 2013-09-13, 06:01 PM
  4. LISP: move dopo di insert
    By dgomez.189897 in forum Italiano - AutoCAD / AutoCAD LT
    Last Post: 2009-03-14, 08:38 PM
  5. Move Lisp
    By lmitsou in forum AutoLISP
    Last Post: 2006-02-24, 02:56 PM
