Summary: Arrowline with an arrow at the end of each line segment.
Description: Essentially ARROWLINE is a feature that, when on, would draw the quick leader arrow at the end of each line segment drawn as it is drawn. The arrow head would be located alined with the line with its tip at the second endpoint disignated. This would continue as multiple segments are drawn resulting in a pathway directive arrow.
How Used: This feature is used to draw direction of flow lines in process and electrical one line diagrams. The user starts at the source side of a signal or flow and draws any number of line segments which all contain a process/signal designator and end in a directional arrow. The result is a clearly designated line with both purpose and direction of flow drawn right along the line.
Feature Affinity: Linetype
Submitted By: James Hall on April 3, 2006
