dandan_2
Once a file has been opened in 2007 and saved back to 2004 file format, you can no longer open the file in ADT 2005/2006 and insert blocks or dim styles from Design Center. We get the following error:
This application has detected a mixed version of AEC objects participating in this operation. Newer AEC objects will be disallowed from participating in this operation
If you answer “OK” ADT 2005/2006 will just hang forever.
If you open the same Drawings in ADT 2007, you can insert away.
The drawing file that we are pulling blocks and dimensions from is in 2004 format.
Any ideas?
Thanks
Dan
