Thread: Field, Object, Viewport, Standard Scale
    Earth
    9,805
    Exclamation Field, Object, Viewport, Standard Scale
    When you create a field to display the "standard scale" property of a viewport, is there any way to modify the default string of "Custom" that is displayed when the scale of the viewport does not match a scale in your standard scales list?
    In other words, can you change the "Custom" to say "N.T.S." ?
    R.K. McSwain | CAD Panacea |
    2004-08
    Iron Station, NC
    3,198
    Default Re: Field, Object, Viewport, Standard Scale
    is there a way to write a lisp that would grab the viewport scale, if it is set to custom, replace it with a string that says N.T.S.?
    I thought I read somewhere that one of the newer versions of AutoCAD is supposed to have the ability for lisp to fill in a field. I could be mistaken.
  1. Replies: 3
    Last Post: 2013-05-01, 04:50 PM
  2. Object / Viewport Scale field in a block?
    By Cavediver in forum AutoCAD Fields
    Last Post: 2012-09-04, 03:22 PM
  3. Viewport Scale Field
    By drafting1 in forum AutoCAD Fields
    Last Post: 2006-12-29, 02:09 PM
  4. Replies: 5
    Last Post: 2005-07-27, 10:55 PM
