Results 1 to 8 of 8
Thread: I have an ename, how do I select the object, using VLISP
    2003-08
    46
    Question I have an ename, how do I select the object, using VLISP
    I have an ename, how do I select the object, using Vlisp in acad2000i.
    The ename refers to an image. I need to select the image from a
    possible set of images. That is why I derived the ename. Now that I
    have the ename of the image I want, I want to do an IWORLDOUT. The
    issue is that I am prompted to select an object if there is more than
    one image present. Which there may or may not be in a given drawing.
    Any suggestions on a way to handle this?
    Joe
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Default Re: I have an ename, how do I select the object, using VLISP
    Hi Joe,
    I'm not sure about IWORLDOUT (and I don't have anything with that command, so this may not help) , but generally you can pass the variable that you put the entity into to a command.
    For example:
    (defun c:test ()
    (setq ent (car (entsel)));stores the ename in the variable ent
    (command "erase" ent); erases the entity ename
    (princ)
    HTH,
    Tim Creary
    S&D
    DILLIGAF
    2003-08
    46
    Thanks for the input, but wouldn't this just present me with another Select Object prompt?
    I tried passing the ename variable "Rstrename" to it but it wanted a point or Last. I tried putting !Rstrename but it still wanted a point or Last.
    Joe
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,434
    Quote Originally Posted by jawf
    Joe
    When you use the IWORLDOUT command, what prompts appear on a successful completion of the command? Can you post the contents of your command line of those prompts?
    2003-08
    46
    I figured it out. I just use the following
    (command "Iworldout" (eval rstrename) "" "" "Y")
    This works if there is an existing TFW file. I will have to check to see if there isn't an existing TFW and alter the command accordingly
    Must have been weary last night. Thanks for the help.
    Joe
    Lost
    1,473
    Hi Joe,
    It was only an example showing how to pass it to a command.
    Could you post what you have so we can have a look at what you are trying to do? It'll be a lot easier that way.
    Also, what does IWORLDOUT do? Is this one of your programs, or a command in a vertical?
    Tim Creary
    S&D
    DILLIGAF
    Lost
    1,473
    I guess I should refresh before each post. Thanks Opie
    Tim Creary
    S&D
    DILLIGAF
    2002-01
    jUSt Here (a lot)
    8,434
    Quote Originally Posted by timcreary
    No problem.
  1. ename issue
    By parkerfeldman in forum AutoLISP
    Last Post: 2009-08-21, 02:53 PM
  2. Unable to select an OLE Object
    By fishervb in forum AutoCAD General
    Last Post: 2006-05-31, 02:36 PM
  3. How can I select last object
    By avinash00002002 in forum VBA/COM Interop
    Last Post: 2006-04-07, 05:41 PM
  4. Fix the VLISP/ActiveX object-management bug
    By sinc in forum API Wish List
    Last Post: 2004-09-21, 08:10 PM
  5. Replies: 3
    Last Post: 2004-06-14, 06:50 PM
