Results 1 to 9 of 9
Thread: Style Based Control Versus Layer Based Control
    2006-04
    Default Style Based Control Versus Layer Based Control
    Good Afternoon,
    Does anyone have insight into whether to continue using layers to control objects with Civil 3D or to just use the styles to control everything? Any specific problems or advantages to either?
    Thank You in advance for your input.
    2003-01
    100
    Default Re: Style Based Control Versus Layer Based Control
    I am kind of surprised this hasn't been moved to Civil 3D yet.
    Up to this point, I have used only a layer based template and I am beginning to see why the style based template is offered. No one here has any discipline at all regarding layers and with Civil 3D layer based some elements can get 2 or 3 layers deep. I now have a layer management nightmare when plot time comes. I am going to set up a style based template using STBs instead of CTBs and try a project with that as soon as it is ready to compare the results and I am expecting to find it easier to administer.
    13,654
    Hi "FCahill" ( Sorry, I do not know your real name )
    Please note I have *moved* this thread from the CAD Standards forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Manager
    2001-05
    Austin, TX USA
    2,201
    Quote Originally Posted by FCahill
    Good Afternoon,
    It depends on what is going to happen to the drawing down the road. Is anyone not using C3D going to be working with these drawing? Then you may want to go with using layers. That way they can change appearance of the objects and turn the visibility of objects on and off. If every one that is going to work on these drawings are going to be using C3D, then you you shouldn't have any problems with using styles.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    2005-12
    40
    Whether your Civil 3D drawing is layer controlled or style based, if the drawing is to be used by someone without Civil 3D there will be problems. Unless you just send them a drawing full of proxy objects, you will have to export to AutoCAD and the results can be far from ideal. I just exported a 2006 Civil 3D drawing to a client that needed r2000 format. This was a very simple site plan with one surface that I exploded and survey points that had one point group defined for some spot elevations in addition to the "all points" group. There were no other Civil 3D objects. The resulting file had everything exploded except the polyline contours. Even the point symbols were exploded. Even though the points had been separated into two layers, the labels all came in on the same layer for both sets. To avoid this with a layer based drawing, a separate layer for point annotation for each point group must be established. The same problem will exist for each type of object that must keep different sets of objects and I have found it difficult to get the program to cooperate with putting these items on separate layers during creation. I often have to manually change the layers afterward because regardless of how I set the creation method it will not take. I do not know if a style based drawing with fewer layers and display properties hard coded will be any better, but I think it is a method worth exploring.
    Active Member eckdahlrd's Avatar
    2016-01
    Kansas City, MO
    59
    I prefer the layer based, simply because then I can manipulate the layers in an xref.
    I have had good success in converting the drawings down to 2000i for clients. I'm not sure if you have tried using Autodesk's DWG TrueConvert program with a style based drawing, but it works very well with a layer based drawing...and it works quick too!
    Robert
    2003-01
    13
    Use both!!!
    I recently completed the creation of over 100 styles and have quite a few layers associated with the individual components.
    Derek Lash
    Member DIN A0 Studio SL's Avatar
    2009-10
    Madrid (Spain)
    30
    Hello to all
    I want to teach a video to you
    http://www.youtube.com/user/DINA0Stu.../3/fGYb3DuH9iU
    I need your opinion
    Thanks
    2009-08
    The video tutorial looks really good. However, I wish I understood Spanish better.
  1. 2010: Nested Profile-based Sweep in Window Family -- Flip Control When Loaded into Project?
    By bevanson509612 in forum Revit Architecture - Families
    Last Post: 2015-03-19, 03:31 PM
  2. Schedule to control pattern based curtain panels?
    By mui in forum Revit - Conceptual Design Tools
    Last Post: 2011-10-21, 12:39 AM
  3. Layer Based Elevation Control
    By IanR in forum AutoCAD Wish List
    Last Post: 2008-10-12, 04:14 PM
  4. Control families visibility based on view scale!
    By tha in forum Revit Architecture - Families
    Last Post: 2007-11-21, 06:06 PM
  5. How to set-up style based pen types-
    By ntowne in forum AutoCAD Plotting
    Last Post: 2006-11-14, 05:10 PM
