Results 1 to 10 of 14
Thread: slow switching drawings and slow commands
    2003-06
    21
    Default slow switching drawings and slow commands
    I'm running ADT as Autocad 2006. I've just bought another new machine and installed Autocad (full install).
    The problem:
    When I go to switch between drawings (nothing very big, simple linework and text) there is a defininte lag (3 to 4 seconds).
    The same thing happens when I select ISOLAYER or the UNDO command.
    I've found similar threads but they all seem to deal with drawing file content/size. None of these apply as it happens on a fresh drawing. There's a variable here to be changed but I can't seem to find it.
    2003-06
    21
    Default Re: slow switching drawings and slow commands
    I just answered my own questions...
    My "make objects layer current" wasn't working so I found this thread
    http://forums.augi.com/showthread.ph...hlight=AI_MOLC
    I had renamed my acad.mnu (mnl) file to something else and so it wasn't reading the original acad menu file anymore. I've made a copy of the original and renamed acad.mnl to my new menu name and "SHAZAM" it works great.
    Thanks Mike for your work on this forum.
    2003-06
    21
    Actually it didn't work completly.
    It appears that It is still slow switching between drawings and the ISOLAYER comand and make object layer current are still slow.
    HELP
    13,657
    Question Re: slow switching drawings and slow commands
    Hi
    Do the drawing files Open ok! on your new computer ?
    Is it only AutoCAD experiencing slow problems on your new computer ?
    Have a good one, Mike
    Earth
    9,829
    Quote Originally Posted by vance.smith
    HELP
    How are you switching between drawings? If you try different methods, is the speed problem the same?
    R.K. McSwain | CAD Panacea |
    2003-06
    21
    Drawings open okay on the new machine. This will happen even if I start from scratch with a new drawings so I know it's not content that's giving me problems.
    Only Autocad and only some commands.
    Actually, I just played with something.. I kept hitting _AI_MOLC and and interesting thing happend....
    the command was slow only on the 9th or 11th try when I clicked fast. When I clicked slow, only the 3rd or 4th one was slow - hence it was slow about every 10 seconds. Very weird.
    Exact same thing with LAYISO - every 10 seconds it's slow
    Thoughs
    2003-06
    21
    Same thing applies with switching drawings - within 10 seconds, it's fast, after 10 seconds or more it is slow.
    BTW, my autosave is every 10 minutes.
    There HAS to be logical explanation here somewhere.
    Earth
    9,829
    2003-06
    21
    Just clicking on WINDOW and then selecting the drawing
    Earth
    9,829
    If you use Ctrl+Tab, do you have the same problems?
  1. 2013: ACAD 2013 SP2 Shift-Deselect works, but super slow. Issuing commands is slow.
    By Professor Lavahot in forum AutoCAD General
    Last Post: 2013-08-05, 03:41 PM
  2. 2011: ACA 2011 Slow in Switching Files
    By gbooth in forum ACA General
    Last Post: 2010-07-21, 10:26 PM
  3. 2009 slow switching between drawings
    By dzatto in forum ACA General
    Last Post: 2010-02-18, 03:31 PM
  4. Slow commands and switching of layouts
    By g_wong in forum Hardware
    Last Post: 2009-02-12, 03:36 PM
  5. Switching Projects is slow... why?
    By paul_mep in forum AMEP General
    Last Post: 2008-08-07, 07:43 PM
