Thread: Customizing Land XML Report
    2003-03
    137
    Default Customizing Land XML Report
    How do I customize a report from Land XML? I am currently using LandDesktop 2005. I have created an XML Alignment Station and Curve Report. I need this report because it lists the Northing & Easting Coordinates. At this point I cannot get coordinates for Curve P.I.'s. How can I add that information into my report? I have looked into customizing my report, but that deals with just adding information in spaces they have created. Also, is it possible to export out only the information I want from XML into Microsoft Excel? Thanks!
    Civil Engineering Moderator MHultgren's Avatar
    Central Iowa
    1,429
    Default Re: Customizing Land XML Report
    To truly customize a report, you would need to create or edit an existing XSL file (Style Sheet) or DTD file. Then you would need to include the tags for your Curve PI's and any other information you want to include. This would insert the data for the Tags and Identifiers along with any applicable attributes (not the Block Attributes, but a type of setting, that you may want to apply to the data). Below is an example of what an XML attribute is and does.
    You can find these files in the following folders C:\Program Files\Autodesk\LandXML Reporting 6\Support\xsl\. There are also some Getting Started files in the C:\Program Files\Autodesk\LandXML Reporting 6 folder to help you figure it out a little.
    Mark Hultgren
    Just a Lurker
    http://www.MKW-Ind.com
    Blog
    Socializing??
  1. CP23-2: Customizing Land Desktop with VBA
    Last Post: 2013-03-30, 02:05 AM
  2. LD41: Customizing Land Development Desktop with VBA
    By Autodesk University in forum Civil Design
    Last Post: 2012-11-19, 03:44 PM
  3. Land 2008 a Land 2006
    By rcruz30 in forum AutoCAD Land Desktop - General
    Last Post: 2008-07-28, 06:45 PM
  4. Land DT 2008 not Compatible w/ Land 2006 ?. wtf
    By mlclodfe in forum Land Desktop - General
    Last Post: 2008-06-11, 07:20 PM
  5. Land 2008 a Land 2006
    By rcruz30 in forum AutoCAD Civil 3D - Land Desktop Companion - General
    Last Post: 2008-04-24, 10:20 PM
