Hello-
I have been having some trouble with this one routine not working properly. I want the routine to copy or move selected objects up 60'-0". It works great except every once in awhile I will got to use it and it will copy or move the objects up 47'-2 3/16". Then if I repeat it right away it continues coping or moving the objects correctly. I have not idea what I am doing wrong. Any help would be great. Here is the routine that I wrote for it. It might help. I have the same routine just modified to copy instead of move.
[ Moderator Action = ON ] What are [ CODE ] tags... [ Moderator Action = OFF ]Code:(defun C:60U() (setvar "cmdecho" 0) ;Turns the command echo of (setq A (ssget)) (command "move" A "" "0,0" "0,60'") (setvar "cmdecho" 1) ; Reset the command echo (princ) ; Suppress the last echo )
