For those of us who need to bubble things and NOT have them relate to a revision...
Here's a line-based detail component that mimmics the revision cloud. Load the family, select Detail Component and make sure Chain is checked. Enjoy.
I have used revision clouds to represent spray fireproofing in the past, but it's a PITA to have to click so many times to keep from getting huge cloud arcs. So I guess this would be good for that?
Thanks! This is exactly what I was looking for - will be good for my shrubs in plan!
Looks like a floor core picture I've seen before.
Got another question for you....how did you make the detail component....i am trying to do something similiar....
I want to create a different revit cloud, a cloud that has both bubble with the same radii.
thanks.
Hi! Did you manage to create a different Revit cloud? I would be really interested in finding out how
I would like to draw it like this: What I need.JPG
This no longer works in Revit 2021 for some reason. Is anyone using an updated one, or do you know why it is not working? Chain is checked.
Here is a Line Based Detail Item I created a while ago that lets you specify the max size of the large arch and also the ratio size between the large and small arches.
Setting the parameter to 1 means both arches are the same size. setting to 0.5 means it is half the size nd so on. You can also set it higher than 1 if that is easier to understand.
