Thread: Select the Layer toolbar button, nothing happens
    2006-04
    2
    Default Select the Layer toolbar button, nothing happens
    When selecting the 'Layer' toolbar button [equivalent to '_layer] in AutoCad 2006 LT installed 2 months ago, nothing happens. Therefore, it is not possible to select all, or multiple layers to make changes or take desired actions.
    Oper. system is WIN XP Home. I did a repair install to correct Design Center block handling, but this problem with LAYER was not corrected. It did work for a few weeks, but stopped.
    How can I fix?
    13,656
    Question Re: Select the Layer toolbar button, nothing happens
    Hi
    Does the _.Layer command work from the Command Line ?
    Have a good one, Mike
    Earth
    9,805
    Default Re: Select the Layer toolbar button, nothing happens
    Quote Originally Posted by wmarsh
    How can I fix?
    When you run the command, is the command line blank like it's waiting on the dialog to go away? If so, if you then press ESCAPE, does the regular command prompt come back?
    If so, it sounds like the entire layer dialog is "off your screen"
    R.K. McSwain | CAD Panacea |
  1. 2014: Using MTP w/ROTATE in toolbar button
    By straits58 in forum AutoCAD Customization
    Last Post: 2014-08-22, 11:36 AM
  2. Would like Toolbar description to appear under toolbar button
    By danny.139703 in forum AutoCAD General
    Last Post: 2007-05-21, 05:47 PM
  3. Is there an easy way to have a Toolbar button call up another Toolbar?
    By jonathanschade in forum AutoCAD CUI Menus
    Last Post: 2007-04-12, 04:40 PM
  4. Replies: 13
    Last Post: 2006-11-06, 09:38 PM
  5. Toolbar button to switch to a Layer and and execute a command
    By dglaur in forum AutoCAD Customization
    Last Post: 2006-10-27, 01:28 PM
