Every time I open a drawing I have the AutoCAD text window popping up.
For the life of me, I cannot figure out why......any suggestions?
Menu item failed to load: ACAD:&File
Opening an AutoCAD 2000 format file.
Substituting [simplex.shx] for [el______.shx].
Regenerating model.
AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
ucsicon
Enter an option [ON/OFF/All/Noorigin/ORigin/Properties] <OFF>: off
AutoCAD menu utilities loaded.
Copyright (c) 2006 qjchen
Enter b2e to start.
Type TX2MTX to begin.; error: malformed list on input
Type > cx < to draw double arc:
*** Type DSTP to execute ***
Type RefreshBlocks to run program.
LookUp loaded, Enter lookup to run.
type < pipe > to start: Plot Tabs is loaded, Enter PLotTabs to run.error:
extra right paren on input
Loaded new command CheckText.
[c]2004, Andrzej Gumula.
"SPACE.dwg": Can't find file in search path:
C:Documents and SettingsrhallMy Documents (current directory)
P:Cad DwgDChryslerC144(06JS41FrontDoor)
C:Documents and SettingsrhallApplication DataAutodeskAutodesk Mechanical
Desktop 2007R17.0enusupport
C:Program FilesAutodeskMDT 2007support
C:Program FilesAutodeskMDT 2007fonts
C:Program FilesAutodeskMDT 2007help
C:Program FilesAutodeskMDT 2007express
C:Program FilesAutodeskMDT 2007supportcolor
C:Program FilesAutodeskMDT 2007drv
*Invalid*
error: Function cancelled
SPLINE-TO-PLINE by Tony Hotchkiss. Enter S2P to start/nType DALI to Run
Autodesk DWG. This file is a Trusted DWG last saved by an Autodesk application
or Autodesk licensed application.
