Thread: Unknown command message appears on command line, after executing a routine
    Idaho, USA
    184
    Default Unknown command message appears on command line, after executing a routine
    I have written some routines that work just fine, but for some reason I always get "unknown command" on my command line after i have executed the routine. Is there a way to get rid of this? I have placed (princ) at the end of my routines.
    Any help would be great
    Emily
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Default Re: Unknown command message appears on command line, after executing a routine
    Could you post the code so we can have a look and see where it is failing? It would be a lot easier that way.
    Tim Creary
    S&D
    DILLIGAF
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,449
    Quote Originally Posted by eleonard
    Emily
    It appears that your routine makes a call to an unknown command. This could occur when you have too few or too many sets of quotes within a (command call. Are you able to post your routine?
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Emily
    If you run it in the debug mode, you can single-step through lines of code until you hit the one that blows up. You can also try turning on command echo and running your routine.
    Idaho, USA
    184
    I will try and run the debug first and if it still continues or i can't figure it out i will post my code.
  1. appearing UNKNOWN COMMAND a message while running a dll
    By prasadonnet in forum AutoCAD General
    Last Post: 2008-10-13, 10:33 PM
  2. Replies: 6
    Last Post: 2007-04-23, 01:40 AM
  3. Unknown Command Error, but routine works?
    By Brian Benton in forum AutoLISP
    Last Post: 2006-10-13, 04:16 PM
  4. _ai_molc command returns unknown command message
    By jan.pennabecker in forum AutoCAD Customization
    Last Post: 2006-05-19, 12:02 AM
  5. Replies: 4
    Last Post: 2006-02-03, 07:34 PM
