Thread: Is there a way to Xref files when creating new sheets using Sheet Set Manager?
    2015-11
    Cincinnati, Ohio
    173
    Default Is there a way to Xref files when creating new sheets using Sheet Set Manager?
    We typically X-Ref our title blocks into each .dwg file. So all .dwg files are easily updated. We just now got 2005 version of Auto Cad. I want to know. Is there a way to X-Ref files when creating new sheets using the Sheet Manager? I see there is a way to specify a Template but Templates don’t automatically update when changes are made to them. (Or am I wrong about that?) Thank you for helping a rookie out.
    2001-05
    Austin, TX USA
    2,201
    Default Re: Is there a way to Xref files when creating new sheets using Sheet Set Manager?
    Hi John
    Please note that I have moved this thread from the AutoCAD General forum to this one. I believe it would be better suited here.
    Thanks!
    2001-05
    Austin, TX USA
    2,201
    In your template file Xref the titleblock into it. Then when you create a sheet using the template the titleblock will be xrefed into it as well. Only problem is fields that are associated with the SSM will not work if part of the xref. They will need to be separately added into the template file.
    2015-11
    Cincinnati, Ohio
    173
    Glenn,
    Thank you. I will try that. Ill let you know if I get it working. Again, thanks for taking out the time and responding
  1. CV430-2: Between the Sheets: Using Sheet Set Manager with AutoCAD® Civil 3D®
    By Autodesk University in forum Civil Infrastructure
    Last Post: 2015-08-07, 05:23 PM
  2. Xref from Sheet Set Manager
    Last Post: 2015-07-13, 10:05 PM
  3. Treat Excel and Images the same as CAD files in the Xref Manager.
    Last Post: 2011-11-16, 10:18 PM
  4. XREF usage made visible in the Sheet Set Manager
    Last Post: 2005-10-06, 11:55 AM
