Thread: Real Time Collision Detection
    Wish List Administration
    2006-03
    1,102
    Default Real Time Collision Detection
    Summary: Parts should not pass thru each other when moving
    Description: Real time collision detection in constrained assemblies. A solid should not be able to pass through another solid when "moving" an assembly.
    How Used: The 2 parts to check for collisions would be selected as a constraint.
    Feature Affinity: Assemblies
    Submitted By: Greg Peck on May 10, 2006
    2001-11
    5
    Default Re: Real Time Collision Detection
    isn't this what the Contact Set is all about? Select a series of parts, RMB and select Contact Set. only those parts selected will take collision detection into consideration
  1. DL416-1: Connect the Dots: Model Aggregation and Collision Detection
    By Autodesk University in forum Design Leadership
    Last Post: 2015-08-03, 09:47 PM
  2. Collision Detection
    By stimmo520 in forum Revit - API
    Last Post: 2010-10-26, 01:03 PM
  3. Time Tracker in real time
    By akamarathonman in forum AutoLISP
    Last Post: 2007-07-17, 12:55 PM
  4. collision detection issues
    By rmcelvain.103137 in forum AMEP General
    Last Post: 2007-01-24, 11:13 PM
  5. Real Time Pan
    By mshimatsu in forum AutoCAD General
    Last Post: 2004-12-13, 07:30 PM
