Results 1 to 10 of 17
Thread: _ai_molc command returns unknown command message
    2006-05
    10
    Question _ai_molc command returns unknown command message
    In the layer tool bar, my _ai_molc command (Makes the layer of a selected object the current layer) doesnt work. It says unknown command. What could be wrong?
    Thanks for any help
    Earth
    9,805
    Default Re: _ai_molc command returns unknown command message
    Quote Originally Posted by jan.pennabecker
    Thanks for any help
    What version of AutoCAD?
    Are you using a custom menu as your main menu?
    That function is defined in "acad.mnl" so if "acad.mnu" (or "acad.cui") is not loaded, then "acad.mnl" is not loaded.
    If you copied "acad.mnu" (or "acad.cui") and renamed it, then do the same with the MNL file.
    R.K. McSwain | CAD Panacea |
    2006-05
    10
    I am using autocad 2005 and a custom menu. I cannt find an autocad mnl file.
    Earth
    9,805
    Look in the default location:
    C:\Documents and Settings\username\Application Data\Autodesk\AutoCAD 2007\R17.0\enu\Support
    (items in blue will vary depending on the username, AutoCAD version, and language.)
    ...and you are looking for "acad.mnl"
    2006-05
    10
    Not sure what is going on but I dont have a sub directory R17.0\enu in my autocad2005?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,103
    Hmmm. What folder name do you have in the AutoCAD 2005 folder? Do you have a 16.1? Keep following until you find a support folder.
    2006-05
    10
    I have a support folder directly under acad2005, but no other folders under support. Just files.
    2002-01
    jUSt Here (a lot)
    9,103
    Is there an acad.mnl file in that folder? If you cannot find it there, try searching your computer. You can also try to find it through AutoCAD by copying and pasting the following code to the command prompt.
    (findfile "acad.mnl")
    If there is an acad.mnl file located in any of your supoort paths for AutoCAD, that code will tell you where it is located.
    2006-05
    10
    thanks for everyones help. I got it now.
    Earth
    9,805
    That's why I included this.
    Quote Originally Posted by rkmcswain
    It was only an example, not meant to indicate the contents of your hard drive. There is no way for me to know what language and username you would have found when you went to search.
  1. appearing UNKNOWN COMMAND a message while running a dll
    By prasadonnet in forum AutoCAD General
    Last Post: 2008-10-13, 10:33 PM
  2. MVSETUP returns Unknown command
    By jonathanschade in forum AutoCAD General
    Last Post: 2007-08-10, 07:50 PM
  3. AutoCAD LT 2007 Appload command returns - unknown command
    By tbedrich in forum AutoCAD LT - General
    Last Post: 2007-04-10, 02:09 PM
  4. Rectangle command returns - unknown command
    By rhayes.99001 in forum AutoCAD General
    Last Post: 2006-11-27, 02:33 PM
  5. Replies: 4
    Last Post: 2006-05-09, 08:57 PM
