Spenner
I think i have open up a can of worms were i work.
A month or so i go i spoke with the I.T. guy who sets the Cad Standards well should do but doesn't set anything really.
I think because i told him how my previous company worked to a very good Standard he didn't like that and this morning set around a Memo and a copy of the Standards which i have never seen until now.
Please read the following Memo and give me your points as i want to give him reason why i believe some points he is making to need to looking into. I just feeling that its his way and nobody is changing it.
Memo
We have recently welcomed new staff to the Company and feel we all need to review our procedures to bring them in line with the QA Manual and CAD Standards.
Please review the following points and adopt where applicable:
• Text font style, height and width to comply with company standard.
• D Text to be used as a company standard, M Text not to be used.
• Lower left justification to be used unless required for text setout.
• Dimension to be set to company standard, in said dim layer, text to be ‘Romans’, text height 2.5mm, with oblique arrow heads, as set out in standard company templates.
• Arrows to be drawn polyline and not leader dimensions, the size of which relative to text height.
• Gridlines to be drawn in the grid layer using Polylines, grids to have node points at all intersections.
• X-ref’s only to be used for drawing frames, unless approved. This resolves binding issues when e-mailing drawings.
• Group is not a company standard and will not be used.
• Layers to be kept to a minimum, added layers should only be introduced if needed, each object does not require its own layer!
• Drawing number system to be followed at all times, see attached sheet.
Please review all company standards regarding the initial setout of drawings and scaling systems.
Please sign below after reading. If you have any questions or queries, please speak to Simon or Brendon.
Regards
Management
All your comments would be good grateful so i can put them back to him.
Cheers
Gareth
