Thread: Deleting a point in a tin surface
    2005-10
    80
    Default Deleting a point in a tin surface
    I have a surface i created with grading objects and break lines. I have one place where the TIN meets up that is out of place, really if i could just remove that point my problem would be solved, does anyone know how?
    2005-12
    40
    Default Re: Deleting a point in a tin surface
    Working from TOOLSPACE, expand the tree under the name of the surface you want to edit. Click on the "definition" and you should get a context menu of edit options. Choose "delete point" and select points to delete on your screen.
    2005-10
    80
    Quote Originally Posted by reed.stephens
    oooo, ok, i tried that again, and the first time it told me that the points had to be visible..
    so i tried agina per your instrutions and realized that i had to change the points in the surface style
  1. Warning Before Deleting an Alignment, Surface, Profile, etc.
    Last Post: 2015-05-06, 02:49 PM
  2. Replies: 0
    Last Post: 2012-10-24, 04:55 PM
  3. Replies: 0
    Last Post: 2012-10-24, 04:32 PM
  4. Create an irregular surface from selected point in a point cloud
    Last Post: 2012-03-10, 12:15 PM
  5. deleting surface lines
    By mcretu in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2006-10-01, 10:27 PM
