Thread: Analysis Results as Parameters
    Wish List Administration
    2006-03
    1,102
    Default Analysis Results as Parameters
    Summary: Results of analysis should be exported to the parameters table.
    Description: I wish the results of an Analysis (e.g. cross-section) or of an AutoLimit measurement would be placed in the Parameters Table of the part/asm to which it applies.
    I would like the AutoLimit and Analysis parameters to be grouped like the Model Parameters, User Parameters, and imported parameters. I would like the parameters autonamed such that the name of the AutoLimit or Analysis comes first, followed by an underscore, then followed by a descriptive name. (e.g. CrossSectionAnalysis1_Area)
    How Used: I would use the Parameters to link to other parts, assemblies, Excel calculations, Parts Lists, Balloons, and Text.
    Feature Affinity: Other
    Submitted By: Joshua Petitt on May 19, 2006
    2007-02
    12
    Default Re: Analysis Results as Parameters
    I know this wish is 6 years old, but I would like to know that the usage scenario for this would be. I also would be concerned that as these numbers update you could potentially create a circular reference of equations in the parameters window!
    Josh
  1. Verification of modal analysis Results
    By mecheil2000 in forum Robot Structural Analysis
    Last Post: 2017-02-16, 02:48 AM
  2. ROBOT Modal analysis results are different from other programs
    By erginc in forum Robot Structural Analysis
    Last Post: 2012-07-11, 08:05 AM
  3. Export Analysis Results
    By G_J in forum Robot Structural Analysis
    Last Post: 2012-02-02, 01:53 PM
  4. Buckling Analysis Results Table
    By brhm in forum Robot Structural Analysis
    Last Post: 2010-03-17, 04:17 PM
