Hello I have upgrade from acad2000 to acad2006
I can't use Express tool anymore.
Is there an update of this toos somewhere to download?
Thanks
Thanks
Hi
Please note I have *moved* this thread from the New Forum Users forum to this one, as I believe it will be better served here.
Below snippet is taken from the small print found on the Forum General page ( Click HERE to see a screen capture )...
<snip>
New to the Forums? This is the place to experiment with the posting editor and learn how to interact with our forums. Please experiment here with forum features and commands.
</snip>
Thanks, Mike
Forum Manager
I assume that you still have the Express tools folder?Originally Posted by t.masse.cps
Have you tried MENULOAD to manually load the express tools menu?
Hi
The following threads should offer some help...
Install Express Tools with AutoCAD 2005
AutoCAD 2006 - Express Tools not migrated from AutoCAD 2005
Where are the Express Tools (AutoCAD 2006)
Installing Express Tools in 2006
How to install Express Tools
AutoCAD 2004 - Install Express Tools
INSTALLING EXPRESS TOOLS IN AUTOCAD 2005
Missing Express Tools in AutoCAD 2004
Have a good one, Mike
You must install the ET for 2006. They are included on your 2006 media disk.Originally Posted by t.masse.cps
It may already be installed, did you try the commands EXPRESSMENU and/or EXPRESSTOOLS?
Ref: http://support.autodesk.com/Getdoc.asp?ID=TS1050281
R.K. McSwain | CAD Panacea |
Hello,
I can't load the arx files but I've checked if express funtions already existed and yes, I can extend to block, draw a cloud..I suppose only the lsp routines are still available
but I can't explode a block and keep the attribute as text.
Thanks for any help
Hi
Have you tried un-installing Express Tools, then re-installing them from the AutoCAD 2006 installation CD ?
Do you mean you can't load the ARX files from your 2000 ET? Of course not, they won't work in 2006.Originally Posted by t.masse.cps
If you are trying to make the 2000 ET work in 2006, forget it. There is no reason to do that, the ET comes with 2006, no additional charge. Install the right version and you are done.
