Results 1 to 10 of 13
Thread: What version of dwg with Notepad
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,324
    Default What version of dwg with Notepad
    "AC1018"
    If I open a dwg with Notepad, that text is on the first line of characters. I know it tells what version of ACAD the drawing is. Is there a site that tells about this in more detail? Will it also tell what vertical (LDT, ADT, etc.) the file is?
    0,0,0 The Origin
    8,570
    Default Re: What version of dwg with Notepad
    AC1015 = A2000
    AC1018 = A2004
    AC1021 = A2007
    I don't know why they've started going up in threes.
    This only tells you the file format. I don't know of a way to tell if a vertical product was used.
    2001-12
    St. Louis
    5,407
    Cool Re: What version of dwg with Notepad
    the unofficial acad history page lists the version numbers... if that is correct, then 18 is 2004... don't know about verticals...
    Quote Originally Posted by Maverick91
    "AC1018"
    Melanie Stone
    @MistresDorkness
    Technical Editor
    1,324
    Quote Originally Posted by jaberwok
    AC1015 = A2000
    AC1018 = A2004
    AC1021 = A2007
    and I guess it only shows the file format, but not the software version, like ACAD2005 or 2006
    0,0,0 The Origin
    8,570
    You can make that -
    AC1015 = A2000 A2000i A2002
    AC1018 = A2004 A2005 A2006
    AC1021 = A2007 ? ?
    and AC1014 = R14.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    The number of ACAD versions between a DWG format change, probably.
    0,0,0 The Origin
    8,570
    Quote Originally Posted by Opie
    Yeah, maybe but they didn't do that in the past.
    Still, we've had Version numbers, then Release numbers, now Year numbers so why not.
    0,0,0 The Origin
    8,570
    Come to think of it - that's probably rubbish and you're probably right (even though it's illogical).
    The first time that a new release didn't involve a new file format was R12.
    2002-01
    jUSt Here (a lot)
    9,100
    I was mainly refering to the three digit shift in the newer versions. I don't know much before r12. ~shrug~
    Earth
    9,804
    I don't think the application used to create the file is stored in the DWG file, other than the encrytped data that Autodesk uses to identify it's own apps. http://www.evanyares.com/the-cad-ind...ill-we-do.html
    Remember there are other applications beside AutoCAD that write DWG files, such as DWGTrueConvert, and any licensed applications using RealDWG - not to mention applications using the OpenDesign libraries.
    R.K. McSwain | CAD Panacea |
  1. Replies: 5
    Last Post: 2015-07-03, 11:30 AM
  2. CP222-1L: The Visual LISP Editor: It's Not Just Another Notepad
    Last Post: 2014-12-01, 02:06 AM
  3. Notepad++ Language formatting by file extension
    By Wanderer in forum Software
    Last Post: 2014-03-12, 02:01 PM
  4. CP215-1L: The Visual LISP® Editor: It's Not Just Another Notepad
    Last Post: 2013-05-05, 01:31 PM
  5. Notepad Tip (= AutoCAD as your Desktop!)
    By r.grandmaison in forum AutoCAD Tips & Tricks
    Last Post: 2006-05-05, 01:42 PM
