dfarris75
disclaimer: I haven't read the entire thread...
You can do this thru the "publish dialog box" if your sheets are all set up for the same plotter and such. I ran into the issue a few days ago where my sheets were set up on an old plotter. I added the new plotter to my overrides .dwt file thinking I could publish multiple sets via the overrides, but noooo, I had to go in and reset the plotter in all my sheets first. Then I was able to plot multiple sets. That's one of my quams with SSM. Otherwise I really like it, especially when coupled with fields. Another quam is that you cannot delete or rename a sheet set in SSM (as far as I can tell).
summary: I want to be able to print multiple sets via the "publish using page setup overrides" and be able to delete or rename a sheet set in the ssm.
