Thread: Publisher question
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,129
    Default Publisher question
    Is it possible, using publisher or another route to print a set of drawings to a printer other than the one specified in the page layout? I only need one set of drawings, and I would like to send them to our laserjet, instead of the plotter, but I cant find a way to batch plot drawings and edit the plotter information, without going in to each sheet and changing it that way, at which point using publisher is a moot point, because I could just print after changing the setup in the page.
    I did run a search on the forum and didnt see anything about this
    thanks
    chad
    2002-09
    Madison, WI
    5,674
    Default Re: Publisher question
    I believe that you have to set it up in at least one sheet. From there you can import it and apply it to the rest of you publish list.
    Hope this helps.
    Dave Peterson
    BIM Coordinator
    Acad - 2019 - Revit 2020 w/ BIM 360 - Navisworks - 3ds 2020 - Ensacpe - Lumion - Win 7 64 - i7-8086K 4.0GHz 32GB Ram - Nvidia Quadro P2000
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
    2006-04
    1,129
    Quote Originally Posted by david_peterson
    Hope this helps.
    That did it. Thanks =)
  1. 2014: Publisher Question
    By jdcincy in forum AutoCAD General
    Last Post: 2013-10-25, 06:53 AM
  2. Publisher Error
    By CadDog in forum AutoCAD General
    Last Post: 2009-07-27, 09:29 PM
  3. Replies: 1
    Last Post: 2006-05-25, 09:18 PM
  4. Jaws PDF and Publisher
    By devilfrog in forum ACA General
    Last Post: 2006-03-09, 03:33 PM
