Thread: Object Table Data to Properties box
    Member m.storey's Avatar
    Lancaster, UK
    18
    Default Object Table Data to Properties box
    Afternoon All,
    Here's a blast from the past I'm hoping someone may be able to help me with. I have a surveyor working with CAD on a laptop equipped with AutoCAD Map2000i. We're creating object data to attach to features in advance of exporting them as ESRI shapefiles into GIS.
    Tagging the features is fine, very similar to the way in which one enters object data in CAD 2004 (with which I'm more accustomed). For ease of use though I would like to have the object table data displayed in the properties box, as it is with 2004.
    Can anyone recommend a method or tool I can use to accomplish this?
    Cheers
    13,656
    Default Re: Object Table Data to Properties box
    Hi
    Please note I have *moved* this thread from the AutoCAD Customization forum to this one, as I believe it will be better served here.
    I believe Importing and Exporting of ESRI shape files are functions within Autodesk Map ( and Autodesk products built on Map technology ). If I have this incorrect, I will happily reverse the action I have taken.
    Thanks, Mike
    Forum Manager
    Last edited by Mike.Perry; 2006-05-26 at 09:41 AM. Reason: Correct my poor grammar.
    Earth
    9,811
    I don't know if the properties palette in 2000i was programmed to display object data. If it doesn't show up, I suspect this is the case.
    You can always use the Edit Object Data command (ADEEDITDATA) to view the object data.
    R.K. McSwain | CAD Panacea |
  1. Getting object Data Table Name from Entity
    By sunsat05463998 in forum VBA/COM Interop
    Last Post: 2012-03-20, 10:04 AM
  2. Replies: 1
    Last Post: 2007-04-07, 12:39 PM
  3. Number of Records in Object Data table
    By raj_thapar2003 in forum VBA/COM Interop
    Last Post: 2006-07-31, 07:39 PM
  4. Linking AutoCAD Object Data Table to Access table
    By m.storey in forum AutoCAD Map 3D - General
    Last Post: 2006-05-02, 02:54 PM
  5. CREATING TABLE FROM OBJECT DATA
    By VBOYAJI in forum AutoCAD Map 3D - General
    Last Post: 2006-02-27, 04:06 PM
