Is it possible to dimension to the center mark of a radial dimension?
Otherwise I may have to put in some reference planes.
Reference planes are the only way I know except detail lines
Chris
If you turn on the center mark visible of the object you are dimensioning then you can dimension to it. Do this by picking the object and on its properties there is a check box for center mark visible.
Scott D. Brown, AIA
BECK
Hey, that did the trick.
I didn't even realise that radial objects had that property.
