Thread: setq Selection Set to a variable
    100 Club gisdude's Avatar
    2005-10
    104
    Default setq Selection Set to a variable
    Hi all.
    I am trying to do a select a group of lines using the setq function.
    If i do a select similar of lines i return 930 lines. I want to convert these 930 to polys.
    I do this: (setq ss1(ssget))
    then when i do a pe i will enter ss1 to return the 930 lines. however the command prompt returns " Expects a point or Window...yada yada yada"
    What am I doing wrong on this puppy?
    Any clues, insights, help would be appreciated.
    Thx
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,681
    Default Re: setq Selection Set to a variable
    Quote Originally Posted by rlong.96213
    Hi all.
    Thx
    You would need to start the PEDIT command and then select the MULTIPLE option before providing your SS1 selection set.
    Earth
    9,802
    Something like this should get you started:
     (setvar "peditaccept" 1)
     (setq ss1 (ssget))
     (command "._pedit" "_m" ss1 "" "")
    R.K. McSwain | CAD Panacea |
  1. Replies: 4
    Last Post: 2015-08-29, 04:40 AM
  2. Using SETQ to assign a block to a variable
    By jpcadconsulting347236 in forum AutoLISP
    Last Post: 2014-02-11, 04:44 PM
  3. error: bad variable name in SETQ?
    By stusic in forum AutoLISP
    Last Post: 2013-05-21, 05:46 PM
  4. COND Statement to Setq Variable
    Last Post: 2012-04-05, 08:47 PM
  5. selection variable
    By jasontirone in forum AutoCAD General
    Last Post: 2004-12-07, 04:38 PM
