Thread: AutoCAD 2006 - Set custom profile current, disables access to ACAD Help file
    2005-04
    112
    Question AutoCAD 2006 - Set custom profile current, disables access to ACAD Help file
    This problem could have been posted in the AutoCAD Customization Forum, but I suspect the association of ACAD Profiles with apriori ACAD 06 menus & ACAD 06 .cui files are inexorably linked: I finally created a .cui file that contains all of my custom .mns toolbar customizations that contains a workspace for my 3D work (done thru Transfer Tab of CUI & alot of sequential steps I've lost track of!). I also have successfully created an associated Profile that besides storing certain Options Dialog Box settings, also stores Dialog Box sizes for various commands like: Layer...,Block...,Insert...,Rename...,View...,XREF..., etc.(very useful) and saves my prefered color for Command Line background. But when I set this profile current, I lose access to the ACAD Help system! I get the message: Cannot find help file: acad.chm.
    The Help Folder under Program Files > ACAD 06 contains the identical name & number of files wheather or not this profile is set current.
    How can I kill this bug?
    Active Member ralphsanchez's Avatar
    2004-10
    Austin, TX
    67
    Default Re: AutoCAD 2006 - Set custom profile current, disables access to ACAD Help file
    Have you verified that the Support Path for your new profile contains your help directory?
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL
    3,514
    There is no acad.chm. In 2006 it is acad162.chm and in 2007 it is acad170.chm. I create profiles from scratch with each new version because it's easier than fixing all the problems you're gonna have with an imported one. Expecilly upgrading to 2006 with the CUI.
    Tom Beauford P.S.M. - Civil 2020 on Windows 10 Enterprise
    Design Analysis - Leon County Public Works/Engineering Wrap [CODE] tags around selected text
    Ph# (850)606-1516 Home Page
    13,656
    Hi
    Maybe...
    ID: TS1056781 - Error: Cannot find help file: acad.chm
    Have a good one, Mike
  1. Replies: 5
    Last Post: 2009-02-23, 09:12 PM
  2. Custom Profile will not stay current
    By Steve_Bennett in forum ACA FAQ (Read only)
    Last Post: 2007-05-09, 10:02 PM
  3. AutoCAD 2006 - Where do I find the ACAD.PAT file
    By trud1966 in forum AutoCAD General
    Last Post: 2007-03-25, 03:07 PM
  4. Replies: 3
    Last Post: 2006-01-17, 11:26 PM
  5. From acad (only acad) File\Open I am unable to access my C: drive
    By jaberwok in forum CAD Management - General
    Last Post: 2005-11-13, 07:53 PM
