hi guys
I've currently done a survey and the house has a spiral staircase
has anyone done a ADT Spiral Stair before, i've seem to got to a dead end in trying to do one of these any help,tips of dwg could anyone share
hi guys
When you start your stair from just about any style, go to the properties box, and select "spirl". I believe the default is set to either multi landing or straight.
Dave Peterson
BIM Coordinator
Acad - 2019 - Revit 2020 w/ BIM 360 - Navisworks - 3ds 2020 - Ensacpe - Lumion - Win 7 64 - i7-8086K 4.0GHz 32GB Ram - Nvidia Quadro P2000
"The more you know, the less you know, because the more you know you don't know". --M. Lin
hi dave
thanks for the info, tried to do the spiral and it's a nightmare, ive instead 3d modeled it using my survey notes by using 3d masses
I've attached my attempt at the spiral stairs but can't seem to get the stair railings to work
can some please give me some pointer of how to get he railings to look smoother please as ive spent over an hour trying to figure this out
You Need ACAD/adt 2007. All those new 3d objects for you.
See attached. I'd attach the DWG, but its 2007 format. And don't forget to get a much more powerful computer to crunch them. It took my PC forever to make and then PDF that spiral.
Take a look at this...I don't have time to continue, but I think you could tweak this and then detach the railing anchor and move it over to your stairs made out of mass elements.
Originally Posted by warnoe uk
hi richard
meny thanks for sorting this out, but could i kindly ask you how u did this so i can learn from what you have done.
From what i can see from the cad file is that you may of made mass elements of the hand rails and vertical post and converted it into a railing style?
am i correct?
I created a stair to match as close as possible to your mass element stair. I then attached a handrail to it. No rocket science. When you tweak it enough to match your mass elements, detach the anchor and copy it over to your stair.
P.S. I did that example in ADT2005 using the OOTB tools provided in the base install. No need for 2007 to create the smooth handrail.
RLB
