Results 1 to 6 of 6
Thread: Unable to check "Prefix sheet titles with file name" when importing sheets
    2004-11
    55
    Default Unable to check "Prefix sheet titles with file name" when importing sheets
    Well, the last release i used was 2005, so i was excited that in 2007 you can import multiple sheets at a time. Unfortuanetly for some reason after selecting all the files and going on to the next dialog box where you check the ones you want it, and clicking import checked it gives all the sheets a name of layout1, now i figure if i check prefix sheet titles with file name it would solve my problem, but i can't its greyed out and i can't check it nomatter whaT I do. Is there some setting somewhere that will ungrey this so i can check it?
    thanks.
    2001-12
    St. Louis
    5,407
    Talking Re: Unable to check "Prefix sheet titles with file name" when importing sheets
    I'm going to move this from 2007 General to this forum, as I believe it will be better served here.
    Good luck with your query.
    Quote Originally Posted by b_v_mc
    thanks.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Default Re: Unable to check "Prefix sheet titles with file name" when importing sheets
    i recently had a problem with copying files for use in a new sheet set... anyone know why it doesn't also import the xref's for the dwg files?
    (appologies for partial thread hijacking...)
    S&D DB Sharing Forum
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    b_v_mc,
    This won't help much but I just created a sheet set in LDT 2007 and imported multiple drawings and the option to prefix with drawing names was not grayed out. So it does work in 2007. I could not find a setting to control this but I assume there is one there somewhere.
    Chris,
    I am not sure what you mean by "copying files for use in a sheet set". I have never had a problem with xrefs in a sheet set.
    2004-11
    55
    Quote Originally Posted by jpaulsen
    b_v_mc,
    Chris,
    Yea it worked normally for the other cadtech here, but for somereason it stays greyed out for me. I have no idea whats going on with it.
    2008-09
    9
    Quote Originally Posted by b_v_mc View Post
    thanks.
    Ok im going to bring this from the dead,
    I am having this same problem, I am using ACA2010. When i go to import new drawings into the sheet set "prefix sheet titles with file name" box is greyed out. It use to not be greyed out but now it is. This is very strange and another computer with ACA2010 i am able to check this box. Is there a setting? There is not much info about this anywere. I even created a new sheet set and still have the same problem.
  1. "Sheets" file with linked models
    By diamond in forum Revit Architecture - General
    Last Post: 2012-04-25, 06:17 PM
  2. AutoCAD 2007 "Unable to create Sheet Set file"
    By jramos77 in forum AutoCAD Sheet Set Manager
    Last Post: 2008-05-29, 10:25 PM
  3. Sheet Set Eerror message "Sheet Set File Is Not Valid"
    By acortes24 in forum AutoCAD Sheet Set Manager
    Last Post: 2006-01-06, 12:26 AM
  4. "Plot to File" check box not saved to layout ...
    By rclayton in forum AutoCAD General
    Last Post: 2005-05-18, 02:36 PM
  5. How to Spell-check your Schedules, View titles, and Sheet Titles...
    By hand471037 in forum Revit Architecture - Tips & Tricks
    Last Post: 2004-12-20, 09:11 PM
